| | DISCUSSION - Air Intake / Open Pod / Air Filter | |
| Author | Message |
gorgon1383 MyviX VIP
Age: 29 Location: KLANG / KELANA JAYA Registration date: 2007-12-21 Number of posts: 619
 | Subject: DISCUSSION - Air Intake / Open Pod / Air Filter 21/2/2008, 3:07 am | |
| hmmmm i also not very sure what we call it, but it looks like a big mushroom. what do u think about this stuff, open pod/air intake? if want to install, do we need to change exhaust too? if install got any effect on other part? does it give pickup / increase performance?
plz any1..... |
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 9/3/2008, 9:21 pm | |
| no answer. maybe will be my research stuff... |
shamiin22 MyviX VIP
Age: 36 Location: SEMBULAN, AMPANG, PUNCAK ALAM, TAMAN DAYA Registration date: 2007-12-19 Number of posts: 1347
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 26/3/2008, 4:47 pm | |
| u can try Simota Carbon Charger Twin Flow Performance Air Filter
try surf at www.simota.com
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 27/3/2008, 12:45 am | |
| hmm... had anyone try already? |
shamiin22 MyviX VIP
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 27/3/2008, 8:06 am | |
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 27/3/2008, 11:57 am | |
| nice info bro, price? autorised dealer? |
shamiin22 MyviX VIP
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 27/3/2008, 12:14 pm | |
| rm450 - 500 around that.... made in taiwan ok... they make between K&N & AEM. not sure... try to search... i saw pokju being using it....
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 5/4/2008, 6:10 pm | |
| so nasty... huhuhu...thanx. do u feel any diff or not? whatabout ur piping? |
as_simpleman23 MyviX Warrior
Age: 28 Location: ALOQ STAR - PEnanG Registration date: 2007-12-21 Number of posts: 2342
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 5/4/2008, 6:16 pm | |
| SE 3311 : can u give detail about ur filter?what brand? |
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 8/4/2008, 5:51 pm | |
| i hope so..thanks bro for ur info.. |
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 9/4/2008, 5:33 pm | |
| Please back to the topic
thank you.
as_simpleman23 Northern Region Moderator |
shamiin22 MyviX VIP
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 10/4/2008, 8:19 am | |
| bro SE3311: hope u can share back ur knowledge here?? can upload ur picture again?? tq.. |
SE 3311 MyviX Junior
Age: 35 Location: alor setar ,kedah. Registration date: 2008-04-05 Number of posts: 42
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 10/4/2008, 12:52 pm | |
| here the pic .... open pod DIY the pipeing  the filter  samco hose  install complate  |
jieman82 FOUNDER
Age: 29 Location: USJ16 :: Dengkil :: Putrajaya Registration date: 2007-12-18 Number of posts: 1599
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 10/4/2008, 1:48 pm | |
| se.... may I know what the function of samco hose..... can we do it by our self... _________________  |
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 10/4/2008, 2:47 pm | |
| | jieman82 wrote: | | se.... may I know what the function of samco hose..... can we do it by our self... |
that hose ( samco ) have to buy lah .. bro .. it connet with pipeing & Totalbody . |
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 10/4/2008, 8:39 pm | |
| whatabout if i use air intake without modify my exhaust systm? |
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 10/4/2008, 10:58 pm | |
| i also din modify me exhaust .......... |
shamiin22 MyviX VIP
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 11/4/2008, 9:10 am | |
| se3311: does it give great throttle response??? is it enough by changing open pod only or do we need to change exhaust sytem also??? how much the total cost if you don't mind to tell us... |
EzD MyviX VIP
Age: 34 Location: KLiens Registration date: 2007-12-21 Number of posts: 2390
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 11/4/2008, 9:19 am | |
| | gorgon1383 wrote: | | whatabout if i use air intake without modify my exhaust systm? |
holaa.. air intake will not distrubing your engine setting & exhaust system..itz just make sure your engine burn oil perfectly.. |
shamiin22 MyviX VIP
 | Subject: Re: DISCUSSION - Air Intake / Open Pod / Air Filter 11/4/2008, 10:29 am | |
| Some Info for u all:
Taking the step of removing your factory air intake system has an excellent bang for the buck ratio and as a result is often the first modification enthusiasts do to their new projects. Your new cold air intake will allow colder air in larger amounts into your engine. For reference think of drinking soda with a stir straw vs. a regular straw, larger diameter equals more flow. Depending on your budget there are 2 routes you can take: Short Ram Intake or Cold Air Intake.
A Short Ram Intake which is often referred to as a warm air intake, positions the filter still inside the engine bay, but at a point as far away as room allows.. Although this Intake setup still takes in hot air, a short ram intake has less restrictions and uses a higher flowing filter allowing air to flow much more freely into your engine. The result? Depending on what you buy, about a 4-8 peak hp gain depending on car and other modifications. It may not sound like much but take into account that you will be gaining power from 2000 rpm until redline, meaning your car will be quicker everywhere in the powerband.
A cold air intake (aka CAI) typically has a longer pipe and its filter is positioned low in the engine bay, close to the ground where it can suck in the rushing air that has not been heated by underhood operating temps. A Cold air intake provides significantly larger gains than a short ram, on some applications gains of up to 15 peak horsepower have been recorded although this won't be the case for every car out there.
The vast majority are plug and play so don't worry about having to modify your engine bay any more then swapping intakes. There are a couple of things you should keep in mind when shopping for a cold air intake or a short ram intake. If where you live gets a lot of rain and you plan on getting a cold air intake, consider also getting a bypass valve. The purpose of a bypass valve is simple, SAVE YOUR ENGINE! Referring back to Mrs. Johnson's physics class it's quite simple. Water is heavier then air, when you start to bring water into your intake system through your filter, air will take the path of least resistance and come in through your secondary system aka your Bypass Valve.
Each manufacturer claims to have the ultimate solution, but our dyno tests have consistently shown that Injen Air Intakes produce a bit more horsepower than AEM intakes, even though AEM is the most recognized name in performance intakes. Currently, AEM is the only company that offers a bypass valve. Injen offers a heat/splash shield, simply and effectively protecting the filter from water splashes. An important factor to consider when selecting a cold air intake is to make sure it meets your states smog control requirements. |
