 [WTS] Genuine Pivot Raizin Products
Go to page : 1, 2  Next
Male Age : 29
PostSubject: [WTS] Genuine Pivot Raizin Products   15/7/2008, 10:54 am
By increasing condenser capacity and through improvements made to circuitry, not only gas voltage stability been enhanced, but our newly improved voltage meter means improved voltage supple which in turn means no loss in battery life or performance and the possibility of reaching 100% performance.
Voltage Stabilizer
Mega Raizin by increasing the capacity of the condenser three-fold (compared to Blue RAIZIN), and decreasing both circuitry noise and high frequency impedance the results have been a more stable supply of voltage to all electronic devices, better gas mileage, and improved torque and audio quality.
Benefits
-Improved audio quality
-Increased torque and response and power
-Stabilized idling and improved engine kick over
-Increased headlight brightness
-Improved fuel economy
-Improved battery life
Grounding kits
-Faster engine start-up
-More stable idling
-Smoother and faster throttle response
-Increase low & middle engine torque
-Better millage
-Cleaner exhaust gas
-Brighter headlight output
-Improve car audio sound quality
Pivot VS-ME
Rm490/unit
Voltage Stabilizer
Benefits
Pivot VS-M
Rm390/unit
Voltage stabilizer in combination with supplementary earth bring you electrical efficiency
Raizin brings you not only ideal electrical efficiency and voltage supply stabilization, but with our original circuitry design and our special noise reduction condenser you can enjoy diminished noise and lessened
high-frequency impedance.
Benefits
Grounding kits
-More stable idling
-Better millage
Pivot VS-E
Rm280/set
Benefits
Pivot VS-1
Rm170/unit
Type S can be easily wired by a one-touch connection to the interior fuse box (ignition). It is also possible to switch the power between +B (normal power) and IG+ to match your car model setup. Moreover, peace of mind comes in knowing that the unit is equipped with a delay circuit to avoid trouble caused by power bursts during battery recharging when using IG+ ON.
Newly Designed Honeycomb Condenser
Our exclusive newly designed condenser, which includes honeycomb shapes in various places, has superior frequency response characteristics that help to bring about incredible noise reduction and results in more stabilized voltage, as well as, achieves both optimum high frequency wave responsivity and improvement in electrical capacitance.
Interior Installation.
Pivot VS-S
Rm280/unit
designed for car audio, not only greatly cuts noise, but the stabilized voltage supply to each unit brings you higher quality audio sound.
-Brings you vivid trebles and mediants, as well as, more resonant bass sounds.
-Outstanding results for both standard audio and full component audio.
Pivot CA-VS
Rm280/unit
Engine performance is greatly improved due to a more stable ignition which is brought about by the double effect of a strengthened earthing system and the noise filter circuitry that quickly suppresses noise when the ignition coil fires.
Due to differences in electrical design, the increase in performance level will differ by car model.
Pivot Spark Earth
Rm210/unit
The additional earth wire on our Composite Earth Cable has a conductor circumference 2.5 times the normal wire. This improves the firing speed by reducing voltage loss and increasing conductivity of high frequency waves released by the ignition coil. Moreover, by facilitating ionization during combustion, it improves gas mileage and engine torque. (Patent pending)
Pivot Ignition Earth
Rm220/unit
By simply inserting into the cigarette lighter socket, you can not only improve the performance of electronic devices by supplying a stable source of voltage, but it is also possible to check the current status visa the voltage meter.
Voltage Stability brings Improved Performance
-Engine Torque
-Audio Quality
-Mileage
-Light illuminance
Checking Voltage gives Protection from Performance Loss
-Lower Voltage means Lower Quality Sound / Unstable Operation for all Electronic Devices
-Low Battery Charge
-Battery Life
Pivot Vcapa
Rm280/unit
Shipping charge Rm10 to peninsular malaysia
Shipping charge Rm10 to east malaysia
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   28/7/2008, 10:56 am
bump for the day
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   30/7/2008, 3:58 am
bump for the day
erepull
Registration date : 2007-12-26
Number of posts : 680
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   30/7/2008, 5:42 pm
kent: which one dis product is more familiar and piratical for my car??
may u suggest??
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   1/8/2008, 6:42 pm
i will recommend to install pivot vs-e first then spark earth and ignition cable
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   4/8/2008, 12:13 am
bump for the day
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   9/8/2008, 1:56 pm
bump for the day
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   12/8/2008, 1:49 am
bump for the day
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   22/8/2008, 12:21 am
bump for the day
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   26/8/2008, 6:53 pm
bump for the day
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   3/9/2008, 2:36 pm
bump for the day
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   8/9/2008, 12:26 am
whatabout pivot grounding cable?
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   10/9/2008, 10:58 am
Pivot Grounding kits taken off ftom vs-e
Rm100/set
thanks
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   13/10/2008, 9:48 pm
bump for the day
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   14/10/2008, 1:01 pm
have some picture bro...
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   17/10/2008, 11:26 am
you have to visit my blog for picture, too many picture will make here messy
www.xd-auto.com > earth stabilizer
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   11/12/2008, 12:25 pm
VERY NICE ITEMS BRO!
FREE BUMP FOR U!
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   3/3/2009, 9:53 am
bump for the day
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   22/3/2009, 4:11 am
bump for the day
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   2/6/2009, 11:29 am
bump for the day
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   12/6/2009, 6:49 pm
bump for the day
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   12/6/2009, 11:06 pm
bump bump bump
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   16/6/2009, 1:13 pm
bump for the day
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   29/7/2009, 1:25 am
bump for the day
Male Age : 29
PostSubject: Re: [WTS] Genuine Pivot Raizin Products   21/8/2009, 4:14 pm
bump for the day
Page 1 of 2Go to page : 1, 2  Next
