 [WTS] Bosch Fusion Spark Plugs
3 posters
[WTS] Bosch Fusion Spark Plugs Empty
PostSubject: [WTS] Bosch Fusion Spark Plugs   [WTS] Bosch Fusion Spark Plugs Icon_minitime1/9/2009, 2:43 am
[WTS] Bosch Fusion Spark Plugs IMG_6383-1
Fused iridium and platinum center electrode
If you're looking for the very latest in spark plug technology, look no further than Bosch Platinum Ir Fusion™️. Fusion features a patented, fused iridium and platinum center electrode, combined with exclusive surface air gap firing technology to produce a longer, more powerful spark. Its four yttrium-enhanced ground electrode design outperforms OE iridium plugs by significantly reducing gap wear. This means less stress on the ignition system for quicker starts, more efficient fuel combustion, and a longer performance life. In addition, Fusion's voltage requirement increases less over time versus other iridium plugs for longer reliable performance of the vehicle's ignition system.
Bosch Platinum Ir Fusion™️ Features
-Fused iridium and platinum center electrode, sintered into an extended insulator nose
-Revolutionary surface air gap firing technology featuring Bosch's unique four ground electrode design
-Four yttrium enhanced ground electrodes
-Factory pre-set gap
Bosch Platinum Ir Fusion™️ Benefits
-Reaches self-cleaning temperature only seconds after starting and provides exceptional wear resistance
-Delivers the most powerful spark for the most efficient combustion and optimum horsepower without increasing the voltage requirement
-Resists spark plug wear and oxidation for exceptional performance life
-Ease of installation — never requires adjustment
*Price without installation, installation provided
*Available for various car model
Rm145/4pcs
Shipping charge Rm5 to peninsular malaysia
Shipping charge Rm5 to east malaysia
[WTS] Bosch Fusion Spark Plugs IMG_6384-1
Exclusive Bosch platinum technology with an enhanced design for 25% longer service life.
If you want to experience quicker starts, smoother acceleration and increased fuel efficiency, Bosch Platinum Plus is the spark plug for you. Only Bosch Platinum Plus features a platinum center electrode that's heat-fused into an extended ceramic insulator to eliminate air gaps which exist in platinum alloy-tipped plugs. And now Bosch Platinum Plus features a tapered, yttrium-enhanced v-profile ground electrode that extends the service life 25% longer than the original Bosch Platinum Spark Plug.
This superior design reaches its self-cleaning temperature faster. And with a lower ignition voltage requirement, Bosch Platinum Plus provides reliable starting in hot and cold weather extremes and provides a more reliable spark at higher RPM's without misfires.
Bosch Platinum Plus Features
-Only Bosch uses a platinum center electrode, heat-fused into an extended insulator
-Tapered, yttrium-enhanced v-profile ground electrode
-Nickel-plated rolled threads
-Lower ignition voltage requirements vs. other plug designs
Bosch Platinum Plus Benefits
-Electrode gap remains virtually unchanged throughout the plug's longer service life; no need to clean or re-gap
-Extends service life by 25% vs. original Bosch Platinum, reduces electrode temperature, and improves access to air/fuel mixture
-For complete anti-seize and corrosion protection
-For reliable cold weather starts and superior operation under all driving conditions
Bosch Platinum Plus
Rm65/set
[WTS] Bosch Fusion Spark Plugs IMG_6385-1
Yttrium-enhanced copper core center electrode for 50% longer service life.
Bosch Super Plus Spark Plugs deliver quality performance based on technology that's proven on racetracks around the world in the most sophisticated racing engines. Testing has confirmed the durability of yttrium-enhanced center electrodes. Now Bosch brings these benefits to you in Bosch Super Plus, the longest-lasting copper core spark plug on the market.
Bosch Super Plus Features
-Heavy-duty yttrium-enhanced copper core center electrode
-Tapered, v-profile nickel chromium ground electrode
-Metal glass fused resistor
-Angular, five-ribbed insulator design
Bosch Super Plus Benefits
-Superior reliability and durability for 50% longer performance life vs. even OE plugs
-Improved starting in cold weather and increased fuel ignitability
-Complete anti-seize and corrosion protection
-Maximum interference suppression
-Prevents misfire due to current leakage
Bosch Super Plus
Rm35/set
Shipping charge rm5 to KL area
Shipping charge rm5 to peninsular malaysia
Shipping charge rm5 to east malaysia
http://www.xd-auto.com
sam1578
sam1578
Registration date : 2009-09-20
Number of posts : 1
PostSubject: Re: [WTS] Bosch Fusion Spark Plugs   [WTS] Bosch Fusion Spark Plugs Icon_minitime21/9/2009, 12:41 pm
bro how about the heat range?
PostSubject: Re: [WTS] Bosch Fusion Spark Plugs   [WTS] Bosch Fusion Spark Plugs Icon_minitime21/9/2009, 7:31 pm
Bump 4 Raya!!
» [wts] Used Pivot Spark Earth (Original Made In Japan) SOLD
» [WTS] Bosch HID 8000K H4
» [WTS] Bosch Aerotwins Wiperblades
» (WTS)Bosch Myvi disc rotors. New for RM150 (1pair)
» [WTS]IGNITION VOLTS STABILIZER PIVOT RAIZIN SPARK TYPE 'S'
