Share
 How this brake hose kit can improve ur braking sytem ??
brotherg
AJK Terengganu
AJK Terengganu
brotherg
Location : melaka - shah alam - kemaman - kerteh - marang - k.terengganu - kota bharu
Registration date : 2008-11-05
Number of posts : 279
How this brake hose kit can improve ur braking sytem ?? Empty
PostSubject: How this brake hose kit can improve ur braking sytem ??   How this brake hose kit can improve ur braking sytem ?? Icon_minitime4/12/2008, 12:49 am
http://img29.picoodle.com/img/img29/4/7/7/f_mypart159m_367ba1f.jpg
http://img26.picoodle.com/img/img26/4/7/7/f_mypart145m_7cd75d5.jpg
salam anyone have tried this brake host kit?? if any please help us with ur discussion here???..is it significant imrovement for upgrade
ur brake system with this , especially for those who cant afford to put rear brake system?? tq for ur opinion and discussion here may
Allah bless u with ur kindness helping us..
-im myvixgtclub (terengganu)--- myvix + myvigt = myviXGTclub
prinze
prinze
Number of posts : 4862
PostSubject: Re: How this brake hose kit can improve ur braking sytem ??   How this brake hose kit can improve ur braking sytem ?? Icon_minitime4/12/2008, 2:01 am
mm..it much much better than OEM brake hose..coz OEM juz made from rubber..this brake hose is more effective when u braking..
View user profile http://prinzenma.blogspot.com
brotherg
AJK Terengganu
AJK Terengganu
brotherg
PostSubject: Re: How this brake hose kit can improve ur braking sytem ??   How this brake hose kit can improve ur braking sytem ?? Icon_minitime4/12/2008, 9:41 am
:cheers:tq for ur explanation..so thats mean this kit can give more response to the braking
system?? have u tried it before?? how much does it cost u including installation?? how many
star from scale 1 - 5 you rate this kit?? Very Happy is it necessary to install this kit for those who use
17" rim?? to all forumer let us talk about this warm welcome to u all tq.. bounce bounce
PostSubject: Re: How this brake hose kit can improve ur braking sytem ??   How this brake hose kit can improve ur braking sytem ?? Icon_minitime4/12/2008, 1:31 pm
brotherg : if i`m not mistaken,yes it true enough by using this hose it will give u better effect compare to oem parts.
below are the reason why:
1- braking system need a efficient cooling air to avoid high temp that can caused disc jem.
2- when we use bigger sport rim,definitely it takes a few second to stop because our car no longer can afford the momentom.
i`ve never try it before but base on my reading experience,this is a must change part if u`ve upgrade ur engine.hehehhee..
stokin
stokin
Registration date : 2008-06-10
Number of posts : 3150
PostSubject: Re: How this brake hose kit can improve ur braking sytem ??   How this brake hose kit can improve ur braking sytem ?? Icon_minitime4/12/2008, 3:33 pm
brotherg - engineering wise,it's true.the reason why:
1.a larger disc brake will produce larger friction which will produce enough power to overcome the momentum carried by the car.but,it comes will a number of (quite large on paper) of inertia
2.when u using bigger sport rim,for sure it will take a few seconds more to stop the car on time since the OEM braking system is made specially for the standard rims.but somehow,it still capable to stop the car safe and sound
bear in mind,all i commented is based on paper aka theory only.
brotherg
AJK Terengganu
AJK Terengganu
brotherg
PostSubject: Re: How this brake hose kit can improve ur braking sytem ??   How this brake hose kit can improve ur braking sytem ?? Icon_minitime10/12/2008, 12:07 pm
ok tq guys for ur explaination..is it much better if we use larger brake disc instead not to use this brake hose kit while using 17" rim?? or is it juz enough we use this brake host kit only with the OEM brake system while using 17" rim ?? anyone can rate for this system?? if u have any experience on this u can put a rating at the equation below tq..
OEM brake system + OEM brake hose kit = how many star /5 stars /(need mod/x need mod)
OEM brake system + PRO RS brake hose kit = how many star / 5 stars
larger disk brake system + PRO RS brake hose kit = how many star / 5 stars
rear and front disk braking system + PRO RS brake hose kit = how many stars / 5 stars
p/s: plz take note the above equation is focusing on myvi n/a + 17" rim, im pretty sure above equation seem like anoying..becoz it easier to solve it..but the purpose im asking about this is to ensure im not wasting my money buying unnecessary stuff if comparing im juz driving the standard + 17 " rim myvi....hehhehe
Arrow
PostSubject: Re: How this brake hose kit can improve ur braking sytem ??   How this brake hose kit can improve ur braking sytem ?? Icon_minitime3/4/2009, 5:20 pm
i will definitely choose rear and front disk braking system + PRO RS brake hose kit = a lot of money hv to spend but it the end of the day,speechless satisfactionary..
» RZR Parking Brake Threads
» Rhino Rear Brake?????
» parking brake
» rzr radiator hose rubbing
» Need Grizzly Brake Pads
Myvi Extreme Club Malaysia :: Bengkel Kereta & Jual Beli Barangan :: Wheel , Suspension & Breaking System-
